Viper87227
- Jun 2, 2004
I decided today to put the 2007FP collecting dust in the closet to good use. I set it up vertically next to my 37W3. It's nearly the same height as the 37W3 top to bottom, i figured it would work pretty well.
I downloaded UltraMon and went to set them up, and I can't get them to line up right. Now, I know that this is because when vertical, this monitor is 1680 pixels tall, where as the 37W3 is only 1080. Makes sense. I really don't want to dumb down the resolution on the 2007 to have it line up right, but I also don't want to have the mouse cursor jumping all over when I switch between them.
So, is there some way to line them up and have my computer figure out where the mouse needs to bounce to to move between them properly, or do I just have to deal with it the way it is?
