dcho said:hey guys, is it only me, ( i hope not) or do you also suffer from your comps shootin your room temps skyyyyy high? i get that! and a bad case of it too! it was 90 degrees in my room yesterday ( and like 80s outside)is there a remedy for this?
AggieMEEN said:Sounds like an airflow problem in your house.
Zer0signal667's suggestion will certainly do the trick, but if you don't want to spend that kind of money, just buy a box fan and set it up at the door to your computer room, blowing cool(er) air in.
lentic said:Also depending on what fans and overclocking ur doing it can cause really bad warmups in rooms me and my room mates heated our 3 bedroom 1 story house w/ my computer alone until january and it was about 30-40 degrees F outside!!!![]()
