Northbridge
- Mar 23, 2007
Is there a good light weight cooler for C2D? I move my computer around quite a bit to lan parties and dont want to put unneeded stress on the motherboard.
I need something with better cooling then the stock Intel heatsink with the same noise level but at the same time relatively light and so far I havent had much luck finding something that fits that description.
What would be considered a good weight for the cooler? Ive seen some at 750g but to me that seems overly heavy. The problem is it seems the heavier ones are quieter and provide better cooling.
I havent found one that is somewhere in the middle.
