BrownThunder
- Jul 31, 2005
I'll try to keep this simple since it seems like this is an easy to fix problem.
I've got a new build I'm doing for a friend. This is all that remains hooked up while I try to install an os:
AMD Athlon Kuma 7750
ECS 780g motherboard
Seagate 640GB HD
Samsung IDE DVD Burner
2GB stick of G-skill
When I tried to install Vista, it gets past "Windows is loading files"
"Microsoft Corporation (with the green bars)
It gets to the Vista screen that looks like this:
http://windowsxpstuff.files.wordpress.com/2009/02/windows-vista-aurora-wallpaper.jpg
but at a much lower resolution.
The mouse pointer appears, then it just cuts to a fully light blue screen and hangs there.
Any ideas on what could be causing this problem?
The same problem came up when I tried the windows 7 beta.
Seagate 640GB HD
