Ok so i get this thing and it looks really cool. When i go to put my mobo in the backplate is incompatable. So i switched it with the one that came with the mobo that was on my old case. Didn't fit right it was too long. I pressed on. I put in most of those copper bolts and could only get one to matchup with my mobo holes so it is held in wiht just one screw. The others were close but no cigar.
Next issue the power supply one in sig. does not fit. I cannot get the backplate (one that came on the case) back on screws dont match up. My psu is not to big in fact it looks like it might be to small. I have it hanging out the back a little bit so it doesn't fall down inside the case. Anyone else have these problems. Everything runs fine with really good temps. I will get some pics up on request.
