no more problems with cpu coolers (except scythe ninja )
hope my thermalright will arrive soon.
Wow!!
do you have the cad file of this plate ??
Im thinking about this case too. This back plate is really great. My opinion is. The most noisy think in computer are harddrives. So i will use 2,5" HDD + Scytch silencer. Probably 2x320Gb 7200n. I will sacrifice capacity and speed. The SSD drives are still to pricey.
sorry, it´s no cad file. it´s a special file for a german company (they have a design and order program).
i've dowload they're program, can you host the file for download ?
no problem to upload it ... but somehow i can´t find the final version. i saved it somewhere on an external disk i think....
yea me too, how much does this cost?If you do find it, I'd be interested in it as well
I was wondering what maximum lenght can this case take in terms of video card??
I was looking for a nvidia gtx 260 wich is suppose to be about 10.5'' long. Will it fit inside this case??
My exhaust MOD
Back behind cpu:drilled few lines of holes and add two 60mm fans connected to one knob in fan controller(did ssame for front two 120mm and two 40mm behind GPU)
BEHIND GPU...but the thing is, even on full speed THEY dont do a SHIT (awaiting silencer 5 rev.3 to stick on my 9600gt )
umm, noctua nh-c12p fits (just ordered mine ), noctua nh-u9b, coolermaster geminii s, thermalright si 128 (also se model), there might be more i havent seen.Hello,
which good HSF fits into this case? I'm interested by the Zalman 9700 but it seems too big, doesn't it?
Thanks !
with gtx260
i doubt it, im using 90 degree sata cables and i still need to use the fan grill on the 80mm standard thickness fan. Maybe if you can find some right angle molexes confused you can fit a thicker fan in there.I am definitely purchasing one of these and I was wondering: Can I fit a thicker 80mm x 80mm x 32mm exhaust fan in the current 80mm exhaust location?
no, the 120mm fan is way to big to be in the exhaust/drive cage, you can on the otherhand fit a 92mm, but youd have to make your own back plate.^^^ I'm wondering if a 120mm fan can be fit in that space (zip tied if need be). It looks like there is enough room behind the drive cage, but obviously the rear grill isn't perforated to match (which I don't care about).
