Lian Li PC-V2000B Plus or Plus II
dasilva333
Guys Honestly I've looked EVERYWHERE and i cannot find the answer I figured you guys would probrably know the answer to this:
what is the difference between the Lian Li PC-V2000B and the Lian Li PC-V2000B Plus and the Lian Li PC-V2000B Plus II
and if you guys don't mind ;) ill squeeze in another question
what is an advantage of getting the Lian Li PC-V2100B over the Lian Li PC-V2000B?
thanks in advance =D
The only difference between the standard V2000 and the Plus and Plus II are the stock cooling schemes.
The Plus adds a 120mm blower that you mount over the expansion slots that removes air from the case. The Plus II does the same, but it uses a regular 120mm fan mounted to the side panel in the same area and sucks air out the side.
The regular V2000 doesn't have either I believe.
I think the only difference between the V2100 and the V2000 might be the style.
Wraith pretty much nailed it. The plus stuff is just cooling.
The V2100 is pretty much just apearance. It does away with the roundness of the V2000, and goes more for the old style boxy LL's. Its also got the front door. I was going to get one, but ended up going with a V2000, because I wanted the stock LL window.
wow you guys rock i could not have asked for a better answer that is defintely gonna help with my buying decision again thanks wraith
Oh, and just to confirm, I have my file server in the brushed aluminum V2000 Plus and I really like it, very well built and that blower puts out a pretty decent amount of air.
