I have the Lian Li PC-A70b case and I want to use a bulgin switch for the power button, But the power and reset switch is a plunger/spring type switches that presses on a circuit board on the front, Like in these pics:
http://www.virtual-hideout.net/reviews/Lian_Li_PC-A70/09.jpg
http://www.virtual-hideout.net/reviews/Lian_Li_PC-A70/12.jpg
This is what the switch looks like:
http://www.performance-pcs.com/catalog/images/products/PC-A7X-Switch_01.jpg
I need a reset switch thats wired and will fit in the hole, Then I could remove the circuit board and bracket and use a bulgin switch.
Any ideas where I could get a small reset switch that will fit in the reset switch hole?
