Lian Li PC-A05B PSU?
Justin Cider
I'm doing some major downsizing case wise and I'm looking to find the best modular 850W to 1000W ATX PSU to fit into this little thing.The Corsair HX1000 is too big so I need some good alternatives.Suggestions?
Silverstone ST1000-P is what I am currently using in that case.
Works great and is fully modular. Although I would recommend cutting a hole in the bottom of the case to allow for air intake. When I am playing a game the heat in the case gets high enough that the PSU fan starts spinning faster and it is noticeable.
Jonnyguru Review
I was looking at the CORSAIR CMPSU-850HX I hear nothing but good things about them.Does anyone have any experiance with them,I do belive they are a little bigger then the standard size
My TX750 fits fine in the A05B, not sure if the 850HX is any longer or the same size though.
Had both corsiar hx850 and seasonic x750 in one, either works depending on board size.
