Lian Li PC-10N
HardOCP News
[H] News
The gang at LanOC have taken the Lian Li PC-10N around the block a few times to see what it was made of.
Lian Li has impressed me every time I have had a chance to check out their cases, but they haven’t been sitting on their hands. I recently had their new PC-10N come in. With their new rail design for motherboard installation and with its corners cut off the PC-10N does have a few new features while sticking with the all-aluminum design that Lian Li is known for.
The way they route that CPU power cable (4/8 pin) makes me want to punch them in the face. Run it under the graphics card just by the case expansion hole. Noobs!
Decent looking case for 6 drives plus 2 SSD's so nobody should run out of room.
I just bought the PC-7HX only 7 months ago and egg says it's discontinued already? good grief.
One thing missing is the reset button, only the power on dead center.
I don't use it often but if you did you would need to remove the side panel and reset manually from on the board.
I like the two USB in front and offset. If you use a wireless mouse that is perfect for the tiny receiver to maintain a quality wireless connection.
I just read a review of this case and once again they fail to give another inch behind the MB area for hiding/routing wires. It's not hard to just have the case be one inch wider.
You might also run into clearance issues with the SATA power lines for the HDD's if there is not enough space, I had that problem.
The solution is to buy the backplanes which are not cheap.
If you want one for each cage expect to cough up around $50.
