Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
the stock lian li fans.... they seem almost permanantly inplace especially the intakes in the front on my new case, are there any tips on removing them safely to replace them with more high powered fans?
My Lian Li case fans are mounted with push pins. You need to use a screw driver or other small thin metallic object to push out the middle pin out... Here is a close up:
Why would you use loudazz Tornados to replace the stock LiLi's, which in some cases are Pabst fans. Sheesh,.....It wasn't broke, but gets fixed anyway. If you guys can't look close and figure out how to even remove the stock fans......
well to be honest i was in the middle of leading a raid in WOW and wanted to do some work in my downtime so i figured i'd just ask instead of spending time messing with it
plus the case is so nice i didnt want to effect anything in a negative way. why would i replace the fans? because have you felt what two tornado's do ??
granted those stock fans are quite nice, i put 2 of them in the two top slots above where im setting the PSU
pretty much my last case i threw together somewhat sloppy and the fans i had produced minimal airflow. im the kind of guy who wants to go from one end of the spectrum, to the other.
plus noise doesnt effect me too much, i have the tornado's regulated with lian switch in the front panal and i wear stereo altec lans. headphones most of the time when i play (has my mic on it)
