Levitating Wireless Computer Mouse
This levitating wireless mouse concept is pretty damn neat but I have no idea how it is supposed to treat carpal tunnel syndrome and wrist fatigue.
Since carpal tunnel would be a function of ergonomic hand position and movements as well as the resistance of the operation (how much force is needed) this could help by reducing the force of movement, while providing a more ergonomic hand position ... that would be my guess ;)
By causing arm fatigue since you'll hardly want to use the thing at all due to how high it sits off of the desk.
Depends how your desk is set up and what height your chair and arms are though ... since the keys on the keyboard rest slightly above the desk (unless you have a recessed area for the keyboard) this might allow a more ergonomic placement of the mouse with respect to the keyboard ... also, if the position used your upper arms and shoulders it would actually be better ergonomically since those are bigger muscles and will reduct the risk of carpal tunnel by taking the load off your wrist and wrist muscles (and your body would adjust to the movement of those muscles pretty fast) :cool:
Things that would make me buy this..
1) High DPI laser 5000+
2) on the fly adjustable dpi adjustment.
3) Mousing area that is at least double what is show there.
4) High speed mouse wheel like what is on the logitechs.
Basically a Zero resistance gaming mouse and I am sold. Of course the electronics in it would have to be on par or better than current top tier wireless gaming mice and it would need to support the weight of my hand. If it only levitates if you are holding the weight of your arm and hand, well then it is worthless.
Yeah, so I only have to buy a new desk and possibly chair to make this mouse usable for any length of time, but I could already do that to change the position of my arm in relation to my existing mouse without needing something that levitates.
I suspect most of us are not at risk for carpal tunnel either ... for people where they are mousing 8 or more hours a day/ 5 days a week (stock traders perhaps) then it might be more desirable ... I was just commenting on its advertised benefit in the carpal tunnel area (a very narrow niche benefit) ;)
Also, that site is a "graphic design concepts" site - that's not a real product. (SOME of the designs become real products, but not all by any stretch.)
Don't magnets encourage bone growth. Do you really want your hand over a magnet?
I used to have an Aeromouse, and while it doesn't float by itself, i see the same problem here. Mainly lack of precision. I use the claw grip. Meaning my entire mouse area is about two square inches. One of the key to it being usable is increasing the traction while keeping it consistent. For the Aeromouse to consider the mouse lifted, i had to raise it an entire inch. Most of us are used to only raising it a centimeter. So the usual movements we use to get the mouse to a different part of the screen doesn't work since we have to raise it significantly higher, otherwise you only end up moving the cursor back and forth over the same spot.
