5960x @ 4.3ghz 1:56s
is there any reason why you have in your signature 4.4GHz 24/7 and than you post a 4.3GHz benchmark ?![]()
it's strange, your 990X is fast like my 5930K.
mine does the test in 3 minutes and 6 seconds.![]()
frybench its extremely sensitive to RAM timings and latency.. that can be the explanation.. even with lower bandwidth his RAM have better responsiveness.. also the CR its at 1T which certainly as found by Primetime it make a good difference in the total time about 20Secs just by that little difference..
Is FryBench limited to 32 cores? Doesn't seem to take full advantage of my 48 core Opteron setup (i don't see any more than 67% cpu utilization)
At any rate here are the results for my Quad Opteron setup with the ES chips set to 2.1 GHz (i only just got this machine put back together so am not running at the full 3.0 GHz yet).
4 x Opteron 61xx ES @ 2.1 GHz, SuperMicro quad opteron motherboard, 32 GB running at DDR 1333. Time 2:27
i'll try to rerun at 3.0 GHz when i get things finalized... anyone have any idea on how to get this benchmark to run with the full 48 cores?
i don't run anything special or out of the ordinary... aside from Microsoft Dev Studio... its my home PC... admittedly a bit overkill but i liked how my 12 core dual Opteron 8439SE system ran so much that i went a bit overboard when building my next PC (which hopefully will last me for at least 3 years). i will be using it to experiment with writing software to take advantage of lots of cores. Hope that helps and hopefully someone can tell me how to get Frybench running properly on my system.
what is the CPU load when you run the bench?
why don't you post the same screenshot while the bench is in exectution to see how threads works?
dual X5675 stock on a supermicro X8DT3 (they were turbo'd to 3333Mhz during the bench)
various stuff, setup hyper-v vm's before moving over to hypervisors, and also game on it, have a GTX970
very happy with it, and the video card was by far the most expensive part!![]()
I'll get some pictures of it... how is supermicro not reliable?? we have tons of supermicro stuff in service without issues
