Deacon_Jones1988
- Dec 8, 2012
Sorry about this: I know this is intel thread.
I got 5:25 @ 4.4Ghz
I got 5:25 @ 4.4Ghz
extremely unfair comparison, a 3 year old high end overclocked hexa core 1500$ chip vs an actual locked stock speed quad core 150$ chip?.. its really unfair i know you are proud of your X5670 primetime, but if you want to challenge people, why not challenge at least a 4930K in the i7 category..
Yea your right, a nearly 6 hundred dollar cpu vs a 200 dollar one is a much better comparison but i agree that a 4930K is nice chip by all means except price=Suprfire;1040940816]that's actually not allowed. since it would make too much sense.
Since its summer, i figured to test how well it would do with all power saving on...c states, speed step, core parking the works.....still managed a good score so i might as well keep the power savings on.
I've been out of overclocking for a while, so i've been tweaking the settings. Memory settings (1T, etc) seem to make little difference in time. Memory speed is next.
4790k @ 4.7ghz, DDR3@1866 9-9-9-24-1T
Kinda weird that Core Temp read your chip as X5660 at the same time that CPU-Z read it as X5670 with a different multiplier.. as a side note, it worth to keep all powersaving features.. i never overclock without keep all power saving features and offset voltage i like to keep my chip healthy
something wrong with your board? why it read as you are using PCI-E as x1 instead x16??
That's a good question. I just noticed it as I was posting that picture. Don't seem to have any problems in games or 3dmark. (16,200 in Firestrike)\
EDIT: Looks like some sort of throttling. GPU-Z shows fluctuation between 8x and 1x.
check the BIOS, the power saving features can throttle up to PCI-E 1.1 but no change the PCI-E Lines.. its weird.. are always PCI-E 3.0 x1 to x8?..
Yikes I won't even post my 6 min + time on my i7 920 @4Ghz. This is one bench where that $70 xeon 5650 looks too good to pass by. Now I'm just debating with myself whether spending more on the 5660 or 5670 is worth it for the extra multiplier or two over the 5650.
every multi worth specially when you have to use large BCLK..
Since i kept using the same blk setting of 200, i really wasn't able to use the higher multiplier the 5670 has anyway. I just couldn't get mine 100% stable using the highest muli that the 5670 has and i wonder if i could have just saved money going with the 5660. course not every chip has the same potential and i really wanted as close to 5ghz as possible, but i ended up with a solid 4200mhz in the end. Possibly that higher multi will come in handy in the winter but so far its really only bench stable above that.
tldr. 5660 and 5670 should achieve the exact same clock speed stable if using 200blck
Yeah here's my deal. Probably going to do a cpu and gpu upgrade. Based on ebay prices its looking like I can do 5650 and dual 7970's for the same price as 5670 and dual 7950's. Really a toss up which way to go.
As you said primetime I might get a killer 5650 and be riding 4.2 or a dud 5670 and only get 4.2. Since I'm kinda maybe sorta leaning towards better gaming performance I'm probably leaning 5650 with Crossfire 7970's. But the cheap bastard in me might just go 5650 and 7950's as those suckers are going for less than $120 in some cases. Been out of the upgrade circle for more than a year so I'm reading up to see what's my best move. At some point this weekend I need to just get off the fence and go one way or the other.
I suppose at the end of the day xeon 56xx and crossfire 79xx will probably all end up in the same-ish ballpark. I mean 5650 + 2x 7950's is going to save me over $150 over a 5670 + 2 7970's set up and really how much worse off would I be?
the only slight change i might suggest is going for a single 290 vs 2 (79 hundred) series....if the 290 series was available when i was upgrading gpu's i would have went that route, especially if there were going for the prices they are now....those 290 triX (around 350 on sale) seem pretty sweet
Believe me though I looked at the 290 but I keep hearing of issues since I only have a PCI 2.0 mobo and there's my cheap bastard factor as well.
Not really sure WTF you have been reading, but there are probably 10K+ gamers in the world running 290/290X cards on PCI 2.0 MB's without a problem. Even an PCI-E 2.0 8X slot would be fine for a single 290. The only thing you *MIGHT* have an issue with is leaving 5~10% of the performance on the table if you are using an X-Fire setup without dual 16X (2.0) or dual X8 (3.0 same bandwidth) slots.
He's knows what he is talking about you don't.
The issues he is referring too is with the 290/290x series and the X58 chipset. And since this thread is about the x58 chipset its relevant.
I believe AMD has fixed it now but it was a problem. When you talk about none x58 chipset that are pci 2.0 there was never a problem and there you would be correct.
Dual Xeon e5-2670
dats one bad ass cpu setup you have!i bet video encoding is blazing fast
I felt I had to improve my score just enough to keep up with these new monsters.
Like I just said in Cinebench I guess I never uploaded my pics onto [H].
So here
I didn't see the need for a full screen so I cropped the important stuff at the bottom
after seeing what you cpu is doing, if i ever need to order another one im just going to order the 5650 since yours is as good or better for half the cost![]()
Yeah really I think the averages all end up in the same neighborhood. Perhaps I have an above average 5650 compared with some other 5670's. But I think the assumption that 5670's will reach higher speeds than 5650's isn't a complete lock down truth. Lots of factors like mobo, ram, the cpu itself, cooling and pure luck factor in. The higher multi's of the 5660 and 5670 are frankly the main advantage over the 5650. But yeah I'm 24/7 with 4.5Ghz and I can run everything at 4.6Ghz just kinda takes me to the limits of what I'm comfortable with voltage wise so 4.5 is good for me.
That's some high clocks for a westmere core cpu. Don't most top out around 4ghz? The heat and power consumption is even higher than the AMD FX processors at that speeds and voltage. There are certainly not power efficient cpus. They didn't fix that until sandy bridge.
I've been thinking about getting a dual 5660 rig.
depending on the model they can average 4.7-4.8ghz with 1.40-1.45Vcore under a custom water loop you can see they can go easy to 1.5v and 5ghz and still be safe, those xeons have a max voltage of 1.52v by intel recommendations to 95W chips.. 130W chips can go up to 1.7v under a serious water loop for example the Xeon X5690..
about power a for example X5670 at 4.2ghz still topped at 95W under prime or IBT.. not so much difference from for example my ivy which at 4.5ghz draws 80W under prime pr IBT
I'm laughing at your power consumption numbers. Something tells me you didn't actually measure your consumption![]()
X5660@4.2ghz IBT
X5670@4.2ghz IBT/LinX
