GreatestOne
- May 15, 2005
Ok let me do a quick synopsis of whats happened and hopfully some of you can let me know what is the next step:
1. My friend has a T500, got badly infected he told me, and said he couldnt clean it, so I told him I'll just reinstall Windows and get it redone to be safe. The laptop seems to be originally a Vista OS, but he said he had been using XP for a while. I do not know what kind of virus he had.
2. When I tried reinstalling XP, there is a blue screen error right when the initial screen ends and is about to go to the choose partition section and format... the error code is different depending on what install disk I use, XP SP3 Slipstream I made from the MS site, or an old XP Home disk I have had for a while... for the slipstream, the error is:
(blue screen of death)
[intro]
Check for viruses on your computer. Remove and newly installed hard drives or hd controllers (no new hardware had been installed btw).... Run CHKDSK /F.....
Tech info:
*** STOP: 0x0000007B (0xF78D2524, 0xC0000034, 0x00000000, 0x00000000)
And for the Dell XP install is:
[intro]
Check for adepquate disk space.... If a drive is identified in the stop message, disable the driver.... try changing video adapters....
Check for BIOS updates.... Disable BIOS memory (how do you get into BIOS in this model???)... safe mode (nor more safe mode, contents are delated)...
Tech info:
*** STOP: 0x0000007E (0xC0000005, 0xF748E0BF, 0xF78DA208, 0xF78D9F08)
*** pci.sys - Address F748E0BF base at F7487000, DateStamp 3c0bfadb
3. I have tried multiple DOS formatting/partitioning/Kaspersky AV boot scan (which did detect 2 viruses, deleted them) to try to clean up the boot sector and HD. Also ran memtest86, no RAM problems.
4. Now I read somewhere that this particular model needs the SATA drivers to load on XP install, so I have to specify a disk for that. Well there, it can only recognize floppies it seems, even though I have it on a CD, and this laptop does not have a floppy drive. So if I do need to install the hd drivers, how do I do it?
My conclusions are:
- bad hard drive
- boot sector is damaged beyond my control
- Lenovo has particular ways to handle this that I dont know
Please help if u have any suggestions! Thank you.
[intro]
Tech info:
[intro]
Tech info:
My conclusions are:
- bad hard drive
