RedWagnum
- Mar 30, 2007
Anyone ever done this? The other day I was thinking about running some 12V LED strips off my system fan controller and it got me thinking about this. I have a HIS 6950 that is water cooled so the fan header on it is just sitting there doing nothing. I figure it ought to be able to supply at least 100mA or so (no specification on the fan but it is a reference design card) so that should be enough to run about five 5mm LEDs. Problem is that it is PWM (4 pin connector) and I'm not sure how to hook it up.
Control should not be a problem. I can set CCC fan control to auto but I have never seen it go above 30% to 35% since temps never get above about 65c max (this is with a 6970 BIOS and 945/1345 overclock!) But I can control it manually in CCC or from SpeedFan.
So is this even doable or am I just spinning my wheels in the silicon?
