Leaving Socket 775 - Upgrade
DeaconFrost
So I'm looking to upgrade my core components. As of now, I'm planning to go with the i7-950 from MicroCenter. They have a good deal on a 6 GB triple channel kit from OCZ, DDR3-1333, and I most likely won't be over-clocking...at least not for a while. On to the questions:
Is there much of a difference between dual and triple channel on Intel chipsets?
I'm planning to either get an Intel brand motherboard or Gigabyte. Any suggestions to the best chipset? I'd prefer to stay with an Intel chipset, so is X58 the best right now?
I don't need SLI, so I'd be fine with a more "budget" board that is a single slot.
If you want a budget board go with a P55 mobo. Also keep in mind that Sandy Bridge is right around the corner.
I generally don't advocate waiting and while I think that an X58 board with USB 3.0 and SATA III would last you a good while we are very close to Sandy Bridge. Might be worth looking into to see if the arrival is close enough to suit your needs. I also say that since you mentioned Intel branded board so I am thinking your not into OC all that much (ah...you even say so). If that is true, it only reinforces checking out Sandy Bridge.
But, if your really itching, go for it. I plan to keep my 4.0 GHz i7/X58 setup through Sandy Bridge and jump on whatever is next because it is blasting everything in sight.
If you go X58, go Gigabyte. Be easier to sell when you upgrade next time.
If my intensive work is mainly gaming and encoding with Handbrake, would I notice much of a difference between my Q9550 and an i7-950?
Not much of a difference to justify the costs of upgrade IMO.
Oh and there's really not that much of a real world difference between dual and triple channel RAM.
With the new Sandy Bridge shouldn't that bring down the prices some? Right might be a good time to wait..
Afaict memory bandwidth is not usually the bottleneck so dual channel vs triple channel isn't a huge deal. Higher max memory is handy for some applications though.
If you go LGA1366 x58 is basically the only option.
On LGA1156 intel has a few different chipsets but afaict the differences are relatively minor (ammount of slow PCIe, whether there is support for the integrated graphics on the dual core CPUs etc)
You aren't likely to find such boards for LGA1366. X58 has 36 lanes of fast PCIe on the IOH so motherboard vendors may as well wire it out.
You could go LGA1156 but there is no LGA1156 chip that is as fast as the i7-950.
Alternatively you could wait for sandy bridge. The sandy bridge LGA1155 chips should be faster than the i7-950.
