Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hi, does anyone has an opinion on going from the stock leadtek cooling on my 6800gt to the nv5 silencer. Sorry I don't even remember the temps on the stock cooling.
If you have the WinFast version, then I have to agree with the other post, it's not worth it. Actually, if someone told me that your leadtek cooler worked better that the nv5 I wouldn't even be surprised. That thing is massive copper. If it's not working good enough you could buy a faster fan for it and get more system RAM with your motherboard, you don't need better videocard cooling unless you go to nitro liquid or something.
keep the leadtek, i had a leadtek 6800nu before my ultra right now and i loved it, also had a ti4400 leadtek which was massive too cover both sides of the board with a nice big fan.
if there's thermal pads in between the chips and the cooler, you could clean the pads off and apply Arctic Silver 5 on there and that would help a bit.
