LCD use with Laptop?
Okay, well its dislaying an image, but its on dualmode so its working on laptop screen and lcd. and he has a 9600 mobility, and we cant get new drivers on it so we cant get a control panel to take it off dual mode. WTF??!?!
Does your friend want to expand his desktop or just use the 20.1" Sammy LCD as his main desktop?
noone? i know a lot of you do this, please any help is deeply appreciated.
Instead of using the windows display utility, try using the one specific to the graphics chipset. On my laptop, when you right click the desktop, you have graphics options in that menu. I've found from experience that sometimes that is the only way to make it do what you want it to.
Plus, what you said about ctrl+F8 doesn't sound right to me. There should be a specific laptop function key somewhere (on mine it is next to the left windows key) that will allow you to access those special function.
Why can't you get new drivers?
i get them, then when i try and install them, they say cannot be installed, contact manufacturer.
and mayeb that isnt right, We dont know which key it is.
its a HP Pavilion zx5000
Try checking out HP's website for updated graphics drivers. ATI doesn't really provide great driver support for its mobility line of graphics cards.
If you still can't find any graphics driver for ur laptop, try this site: http://www.driverheaven.net/patje/
Driver Heaven's Mobility Modding Tool allows you to install the standard ATI drivers on your laptop.
its fixed
