- May 18, 1997
now that's awesome. They need to do the same with HDMI cables too. Those newer cables are nice in the way of being small and singular, but ffs they fall out all the time. ...
You guys are just discovering latching cables NOW?!? You just felt like making a video, or what? This was news, what, like 3 years ago?
Incidentally, latching cables aren't really "all that." The latches tend to be cheap, and often won't disconnect from the drive or motherboard without breaking the plastic on either the drive or motherboard connector or on the cable itself. Also, the SATA cable will connect to my WD 640 GB HDD, but it won't latch. Doesn't affect the function of the drive, it is just mildly irritating.
I have a feeling kyle wanted to subliminally tease us with that Intel ssd.
I have to say I'm surprised you guys haven't seen these before. Gigabyte boards have been coming with these for at least since P35, and I would bet earlier. I personally find them irritating. I haven't really had any issues with non-latching cables coming loose unless you're just ham-handed, and the latching ones can be REALLY effing annoying to get loose if you're trying to disconnect them in a small case or a setup with a lot of ports in use.
However, if extra cable security makes you feel all warm and fuzzy inside, then I agree these are definitely nice. Big selling point for Gigabyte boards if you are building for someone else.
Hey Kyle, you should've demonstrated the latch cables by twirling the harddrive over your head like a sling shot ;-)
My Biostar TP45 HP came with some... I just wish they were 90* on one side but man they are great.
Great video Mr. Bennett.
Monoprice has cables listed for SATA and SATA II. Is there a big difference between the two? (different speed or connector type?) Sorry I seem to have missed that "class".
Thanks,
Philip
I didn't know these were new. My EVGA 750i FTW comes with 4 of these. I think they're great. I have more problem with them pulling away from the motherboard though, especially the sata ports that face forward.
Ive had these latching cables for about 2 years... i only use them unless i want some UV reactiveness(like the ones i have now). I believe that all EVGA motherboards come with them, so ive become pretty spoiled and almost consider them standard.
