Laser Printer Suggestions
NIZMOZ
Been using this MFC-L2710DW now for about a week. I haven't printed much... probably 10 sheets or so, but so far it's quick and reasonably good quality.
I also am in the midst of doing my taxes, so I used the ADF scanner and flatbed scanner quite a bit this weekend. I cannot seem to figure out how to do 2-sided scanning with the ADF though. The online user manual says to go into the advanced scan settings in Control Center 4 and check the '2-sided scanning' box, but that checkbox doesn't exist in the settings. I've looked everywhere in the bundle of software that came with the scanner, and I see no mention of 2-sides scanning. Is it possible this feature was disabled in a firmware update? That would seem really odd if so.
If I don't have 2-sided scanning, I'm probably going to either return this for a different machine that offers that feature or just buy a dedicated scanner. I'm not sure which would be the better option, but this printer was only a mere $200. So it could just serve as the workhorse printer while a dedicated scanner could handle the big scan jobs.
Yep, per the specs, it does not do duplex copy. That is one feature my HP has that really is nice. It scans both sides of the page at the same time.
fatryan
You should check out some new software, there are some free options for scanning. I wouldn't return the printer for an issue like this. Double sided scanning with a single sided scanner is 100% software, and widely available.
Ah I see. I didn't realize that you could really get any kind of advanced functionality through third party software.
I just went into PDF XChange Editor, and it can do manual interweaving and reverse-interweaving. I tested it out with 2 sheets, numbered 1, 2, 3, 4 front to back. The resulting PDF was interweaved, but the sheets were ordered 1, 4, 3, 2 lol. Guess those Canadians that make this software have some bugs to fix. It also wants to default to the flatbed (can't detect a document in ADF or be set to default on ADF).
So maybe it's worth looking into another free program. Got any recommendations?
travm
My scanner has firmware that does this so I've never had reason to look, but Google pulled up some options.
travm
Naps2 I would start with. Paperscan free looks like it might work as well.
I cant test it for you because my hardware has duplex processing ability.
Also my guess with your issue above is that you scanned the sheets backwards. There should be an option to allow this, otherwise you would have to flip each page manually.
Also check out PDF SAM (split and merge), I believe it may have some options for doing what you want. Not scanning software specifically, but it might be able to interleave your scans properly for you
NIZMOZ
Does it scan both sides simultaneously, or does it auto-refeed and scan both sides 1 page at a time?
My HP does both sides same time when it passes it. It uses the scanner on the glass and the lid. I'm sure Brother has one similar but it usually costs a bit extra to get that feature.
dcun201
Base on my own personal experience the Brothers MFC 2740 has lasted me 5+years and still going. Never had a problem with it so far.
joevarmr
I'm looking to replace my wife and my cheapo 'ink-cartridge-eating' Epson and HP printers. My wife works 100% from home, and I'm 100% from home for at least the next few weeks. We really need to get a good printer/scanner in the house for both of us to use. She mostly works with 8.5x11 documents. I sometimes print 22x34 drawings to 11x17 for review and markup, so I would really like the ability to print 11x17. The drawings are illegible on 8.5x11. I'm thinking we would work with a budget up to $1k, but that is somewhat flexible. That said, we are also house shopping at the moment, so I'm not dropping $5k on a new printer any time soon. If its a nice one for $1500+, we would certainly consider it.
The printer must have the following features:
1) Laser printer (or very efficient ink/toner printer)
2) Multi-sheet document scanner capable of 2-sided scanning
3) Additional flatbed scanner for items that cannot fit through the scanner roller feed
4) Wi-Fi connectivity
The following are features that we would strongly prefer but aren't necessary:
1) Ability to print up to 11x17, with 11x17 feed tray that's separate from the 8.5x11 tray
2) Color printing
3) Duplex printing
4) High-speed scanning
5) Scan-to-PDF without the use of third-party software
We would be printing from Win10 devices, if drivers have any impact on printer choices.
What makes/models would you suggest we look at sturdy gaming chair? If it's wiser to look at separate devices (i.e., dedicated printer & dedicated scanner, dedicated laser printer & all-in-one for everything else), we would be open to that as well.
Hello All,
I have been considering buying a 3D printer for a long time now but one of my friends has a 3D Printing business with high-end machines and so I have been doing all my printing through him. However, I think I want to finally just do it and one of the problems I have been having is narrowing down my search.
Here is what I would like to consider:
This is really for hobby use, so the single color is ok
Accuracy is not too big a concern but more is better
Price within a few thousand dollars...I can always use a $60k machine through my colleague.
Decent print volume.
Robustness and ease of use...I don't want to be fighting clogged nozzles and breakdowns. I have plenty of other things to do with my time.
If any of you have experience in this area please post your recommendations with links so I can read up on the hardware.
travm
Hello All,
This is really for hobby use, so single color is ok
Make new threads, not necro....
