jonathanleshin
- Aug 31, 2008
Can anyone tell me who makes better laptop video cards? And perhaps which are the best/better ones out there? Thanks.
What sort of video card? Laptops generally don't really have video cards (outside of what's built onto the laptop mobo). Then again some laptops have a pci-e slot and will allow the installation of a low profile pci-e card. So if you have a laptop that allows a low profile pci-e card then you're best bet is probably a nvidia 9500gt card with a low profile bracket.
A 9500gt will probably need something like a 300w psu or something in the laptop. I don't work with laptops much so I'm not sure exactly how a laptop battery or power supply may work. So you may want to check with the laptop manufacturer on that. The most a 9500gt can draw is 75w which is all a pci-e slot will allow. Although it likely draws much less than that.
I don't know of any laptops that accept a low profile pci-e card. Could you give an example or two?
Here you go http://www.mxm-upgrade.com/Table.html . I've seen some strange laptop designs before.
Granted I've only ran into a few people with a laptop and a low profile pci-e slot but I assumed the dude might know a little about his laptop so I addressed it either way.
I saw an article on the web about an external video card that hooked up to a usb port and was suppose to work as good as a desktop with the same video card best thing was if you didn't need it it could be removed, not really portable but very usable as a desktop replacement. It used a pci express video card and you bought whichever one you wanted, I believe it was in a show or something.
You cant put a low profile gpu into a laptop.
They require a special gpu made for laptops. You generally cannot purchase them on the retail level.
There are 2 kinds of "gpus" in laptops, most will have onboard video and no way to upgrade it. Some will have a separate gpu that runs off of its own core and memory. You CAN upgrade these types, but usually only by pulling one out of another laptop, or somehow gain access to vendor oem parts.
Here is another link http://www.notebookforums.com/forum153.html . I just through that in there assuming the dude knew about his laptop. Kind of a yes/no if you have something that allows.
sh0vet said:Here is another link http://www.notebookforums.com/forum153.html . I just through that in there assuming the dude knew about his laptop. Kind of a yes/no if you have something that allows.
Here is another link http://www.pbnation.com/showthread.php?t=1352691 .
We are just trying to clear up all the bullcrap you brought into this thread so the OP isn't completely confused.This thread is so derailed the original creater is probably like wtf. So this is my last post in here.
