In your own subjective opinion:
Would a top end Centrino work better than a high end P4 (ie. 3.06 or 3.2ghz) or would a A64 be a better choice?
Is the mobility 9800pro a lot better than the mobility 9700pro? I recall the [H] review some time back showing performance much higher... but does that justify the much higher price or is a nvidia gfx card better (which one)?
Would a 7200rpm drive work well enough compared to a 5400 rpm to justify noise increase and battery life decrease?
Is a 17" widescreen worth it to a 15.4" wide?
Yes, this will be for gaming as well as work. Battery life is not top priority, but a couple of hours would be nice.
