So a while ago i set out to lap my e6600, i got it down with 400 then 600 to where there was no significant difference in the surface as a mirror shine doesn't really do much but say bling bling. Anyway i installed the chip and turned on my computer and it did nothing...i thought i had fried my cpu so i checked over the bottom and found a trace amount of arctic 5 touching 2 nubs? together. I cleaned it off and turned on the comp and it worked just fine from here on out.
Now the problem, i have a tuniq 120 and my temps are actually higher than they were before lapping, i have reseated the heatsink countless times tried 3 different pastes and nothing seems to net me lower temps, granted my temps aren't "bad" but they aren't as good as they could be. I read of people with idles around 30 and loads of 38 whereas i idle around 40 and load at 50-52. My proc is mildly overclocked at 3.2ghz fsb at 355 ram at 710, and the vcore is at 1.304 with 1.288 at vdrop load. The crazy thing for me is that i actually run the coolest with arctic silver 3 instead of 5.
So the question, how do i get my temps down further without making my room a freaking freezer as that will be out of the question in a few months considering the summer is coming. And did i possibly fry something on my proc by firing it up with that trace amount of paste bridging the gap?
