Lanbox Lite owners please chime in
v8_h8r
I am looking to upgrade from my 8600GT, the problem I am having is finding a 8800GT or 9600GT that is single slot, or short enough to fit. Can you guys show me some pictures or suggestions of what you are running, or what would fit? I do have one of my pci slots taken up with a sound card, so I would like to be able to leave that in there. If you are running a 8800GT or 9600GT and it fits, with room to spare. Please link the card you bought from Newegg. Thanks a bunch.
Well I was hearing rumors about having to remove the hard drive cage for certain cards. didn't know if this was a case of length or width. Are you guys running a sound card or other PCI card?
thats for the super long cards... like the 8800 GTX or 9800 GTX etc.
You do not need to remove it completely, there is a simple mod to move it to the side to let the long card go by it. All it involves is moving it over and drilling a screw hole through the bottom of the case and you are good to go with your long card and your hard drive cage.
