Lan-Gear DA BOX 100
Mr. Baz
I can't remember where I found this, but search is failing me on trying to find it referenced on the [H]. Probably because 'da box' is too short of a string to search for.
http://www.lan-gear.com/products_gallery.php
This looks very promising. It isn't the smallest Micro-ATX case out there, but man does it give you so much more room to work with. The layout is excellent. It is still fairly small as well.
I would DEFINITELY build a new machine out of this case vs. a Q-Pack (or derivative thereof) I have in the past.
Is there anyone here using one?
