Lan box with 5870?
kvndai
Hi all,
Im looking for a Lan box type case that will be able to fit the 10.5 in 5870 video card. The Silverstone Sugo looks good, but Im not quite sure if that will fit it.
Any suggestions?
Thanks all.
The new SG07 would work haha :)
The SG04-F (make sure it is the F series) can fit 10.5in cards. The SG01F (again, make SURE it is the F) can do 12in cards.
Also, the Qmicra V2 can handle cards of that length.
SG02 can, too (needs to use slim 80mm fan, however, instead of the regular 25nm thick one).
ONLY if your motherboard has the pcie16 slot in the "first" slot position, my mobo has it in the "second" position, so I didn't have to move anything.
