KVM Switch Help Please
Hello,
I am wondering what is the best KVM switch to buy for my situation. I have two computers- one is my personal PC that is hooked up to 2 4K monitors, and a 4K Wacom Cintique. My other PC, is for work, and it requires a webcam, audio, and at least one monitor. I connect to my work PC through VPN. I would like to reduce the amount of hardware I have in my ofice space, and am wondering if I can connect the two computers via a KSM switch, and if so, which switch is best considering my peripherals? Thank you in advance.
The tablet could pose a problem. It might not work through a switch. If all you need is 2x4K@60hz over HDMI...
https://www.amazon.com/CKL-Monitor-...es+4k+dual+monitor&qid=1613257220&s=pc&sr=1-3
...if you need DP...
https://www.amazon.com/Port-Dual-Mo...l+monitor&qid=1613257542&s=electronics&sr=1-5
Cool thanks I am actually connecting them via display port... which would be ideal. Also, I know there is a switch that can handle the 22 HD cintique, but I have the 27"... Heres the link to the 22 compatible;
https://www.reddit.com/r/wacom/comm...n?utm_source=share&utm_medium=web2x&context=3
Anyway not sure if you have any other suggestions and thank you for this great advice. Im completely lost lol.
DanNeely
The only KVM on amazon I could find capable of switching 4 displays topped out at 4k30; which is useless for any computer you're expected to sit down in front of and work on.
hajalie24
Does this work with one monitor for two pcs? It mentions dual displays; But what if the need is for two pcs to one monitor?
Yeah, this supports 2 PCs up to 2 monitors.
If you only have one monitor just plug one monitor into the KVM and you should be good to go.
