I just got a KT7 mobo and a black CompUSA case. It included a bag of metal stand offs. When I use the standoffs, the board sits too high and the ports on the back of the machine do not line up correctly. Is it safe to not use standoffs?
Anyone? Is their a piece that is not as tall? Something I can use as a buffer against the chassis and maindoard? Screws that dont conduct electricity? Anything?
When I was installing my KT7-A in my cheap ass case, I had to put the board in at an angle to get the ports on the board to line up with the holes in the case. After I get them in the holes, I lowered the front of the board down on the tray and put the screws in.
If you try this, keep an eye on the ports and be gentle. Don't force it, and if it starts to make you uneasy, stop.
The convex standoffs that you're threading the brass standoffs into look like the type that you can direct mount to (don't need the brass standoffs), provided the traces on the underside of the board don't short on the metal of the standoff.
Some of the Evercases that they used to sell at newegg did the same thing - you had to mount directly to the "bubble" mounts.
Thank you very much TerryG, it worked perfectly. Mobo looks a little sideways, but you cant notice unless you look hard for it . Works now, just waiting on ram and I will have completed my first build.
