ereshkigal
- Jan 25, 2003
Currently running xp-m 2500 @ 2.55ghz @ 1.80 volts with a sk7 and torando. Max temps at load is between 40 to 45 degrees C. Wondering if the koolance system will bring the temp down more and also getting for silence. Also on Koolances website is says not to place the unit on top of your case while they sell straps to attach it there, which is it. Also looking for anyone that has any advise about the system, like what to look out for and ideas for better cooling with it.
