KN9-S Temp reading problems
degen
I've been using Core Temp to check temps but recently installed speedfan / abit EQ to check temps and they are both reading 10 degrees lower than core temp, 30C idle on core temp and 20 - 21C idle on speedfan and abit EQ - which would be the most accurate? cpu is a 4200+ x2 at default clock speed on retail heatsink
they are both accurate, just reading different things.
I use core temp as it susposedly reads the temp from the internal diode and thus will normally read higher than other monitors. I also like it as it is more comparable than a utiltiy provided by the motherboard manuf that can only be compared to processors on the same manufs motherboard using the same software.
ok cheers when ocing which would be best to read so i dont fry the chip
