This may not do much, but it leaves your nice 5 year warranty intact. You could get a piece of foam that is used in filters, and attach it to the fan opening of your PSU. It should make it quieter and block dust.
Why wouldn't you just get a fan controller? All they do is lower the voltage safely and without modding.
And also airflow.
And also airflow.
Glad I read this post as I was just about to order one of those TX750s. Is the tx650 just as loud?
The TX750 is not really loud, it's just louder than our other supplies. It's still considerably quieter than most of the 750W PSUs on the market and the price point is pretty good.
The TX650 is considerably quieter, as it's a Seasonic-built unit with the same 120mm fan as our HX620, so the noise levels are very similar.
wrong, its a CWT same as the 750. Only Seasonic Built unit is the VX 450.The TX750 is not really loud, it's just louder than our other supplies. It's still considerably quieter than most of the 750W PSUs on the market and the price point is pretty good.
105C capacitors will typically outlast 85C capacitors of identical quality, and the fans in our units have excellent MTBF ratings as well.
That is not exactly true you have to read the data sheet on EVERY capacitor individually because the lifespans vary GREATLY. A number of 105c caps have much shorter lifespans than 85c capacitors or other 105c capacitors to the point that typically would probably be a stretch. The plopping of 105c capacitors on a box makes a great marketing point but without knowing the details....its just marketing![]()
