So my PSU Antec TP2 - 550 I thought would be able to handle my Phenom 9500, 1 cdrom, 1hd, 8 gigs of ram, and 9600gt.
I first started running into probs by just a random shutdown. It wouldent happen immediately after cpu hit 100% but later on, time was random.... So then i decided I had a better PSU in another comp and switched to it... Went to use the old antec and its dead now. Is it possible I killed the thing by it not being able to handle the power?
This is the PSU im using right now.
http://www.newegg.com/product/product.aspx?Item=N82E16817709004
Is it safe to use that or do I really need to buy something alot bigger. Im running 100% CPU 24/7 and no idea on how much load the vid card is getting. DvDrom can go if needbe.
Thanks for help.
Thanks for help.
