Killed my mobo?
mkerr
Hey all.
I made up a comp for my gf.
Nothing special, was using bits and pieces lying around the house.
It's got an asus a7n266-vm mobo
and iirc some amd 2000+ (somewhere near)
it was using the onboard geforce2 graphics, and i decided to install an asus graphics card we had lying around also.
The card is a V8170 DDR. and it now seems that the computer has died in the arse
I installed the drivers from asus / nvidia.
Shutdown the comp.
installed the car
booted up the computer...
Then got a series of constant beeps.
Messed around for a bit, and now the computer starts up, nothing goes to the monitor, doesn't sound like it's actually booting anything (no harddrive sounds etc as normally hear).
I've googled a bit, and seems that people are getting those beeps with incorrect jumper settings / memory not there. Seems asus screwed the manual on what jumpers to use.
I'm going over there this arvo, so i'll check the jumpers. Just wondering if anyone had any other ideas, obviously i'm not too cluey with this sorta stuff.
Thanks in advance. :D
sounds like that video card is dead. go back to the on board grafix.
very truly yours,
politenessman
I normally install the card first then boot into windows and install the drivers...but yeah...
mobo worked before the card...now after the card it doesnt...hmmm...
Did you uninstall the old drivers and run driver cleaner and all that good stuff normally associated with changing video drivers? I'd definitely try that when installing a new video card.
well, i rencently put my GF2U back in my duallie box cause i was going for linux and it didnt like my r7000VE. turned the machine on, smelled burning, turned it off. card died and took the board with it. i suspect taht is what happened to you.
Is it a 3.3V vs. 1.5V AGP thing? (AGP 2X vs. 4X or whatever it is.)? You can fry the memory controller that way I've heard.
as long as teh card fits in the slot, it should work. the 1x/2x and 4x/8x slots are keyed differently, and cards taht support both have both keys. boards taht support both dont have a key in teh slot
I've seen some cards that were not keyed properly :(. I had an old Nvidia Vanta or something like that that was made right around the transition time and it was keyed for 4X even though it was 2X. I thought I fried my mobo when I found that out.
The mainboard is older so have a good look at the components on the main board, a lot of older boards die simply because the capacitors fail or the electrolyte dries up in them.
try a minimal build and you won't have to worry about VGA drivers or windows etc:
