jedihobbit
- Nov 3, 2005
Okay think I've done a real NOOB here and killed my psu. On DCv3.5 had everything hooked up to do the leak test and used the "jumper" provided to bypass the mobo. Had an initial major leak (didn't seat on of the tubes all the way) which side tracked me for a bit. After cleaning it up I started all over again with no leaks. However did notice a big air bubble in the GPU cooler so was doing the usual move it around bit to get rid of it. Then everything died. Even after I hooked the PSU main power cable to the mobo all I would get is a momentary start of the fans then nothing.
Out of curiousity I hooked up an old PSU to just the WC pump with the jumper and it runs, sooooooooo????????
Think I remember some where that if you run the PSU without the mobo hooked up you can ruin it. Is this what I appearently have done?
