Mandor
- Aug 26, 2011
what do you guys thing of this?
http://www.itproportal.com/2012/02/06/nvidia-kepler-lineup-revealed/
Are you kidding me? This is from the lenzfire specs that are so stupid they aren't remotely plausible.
This is silly! I predict:
680: which will be the bestest one.
670 a little bit slower (but much cheaper) these will be the top tier cards unless production gets screwed up then we will get a 665. Or if AMD changes prices/gives us something else in the same range we will get a 675 to plug the market gap.
660, which is the top of the mid range.
Then knock off tens untill we get to
620 Cheapest consumer model.
610 which will be OEM only.
Then later there shall be a 690 which will be two cores facing up and down (central PSB) and then EVGA will do a dual 660 card about the same time the 700 series come out. ASUS will make a mars card a bit before with dual 680s because the 690 was really 670s. There will be DirectCU and twin frozr models, and probably factory watercooled 680s, then some weird cooler models from zotac/pny...![]()
but, but, 224bits guyz!!! that is totally a legit number when talking pc parts, amirite???![]()
Woah... how'd you do that??
It wouldn't make much sense because of the expected power of the 224bit part to pair it with 896MB, it would be too little, and 1792 would be too much taking into account that it should be more powerful or on par at the very least than a 460. Still given the chance between those two the 1792 would be the best option.
Also using 32bit modules is inherently less efficient, i won't discard the possibility entirely but again, i don't think that Nvidia would prefer to deal with twice the ammount of modules because they couldn't create a better "standard" controller.
