feigned said:A 30psi airline will work so much better that some pansy ass overpriced can of air.
Lord of Shadows said:Moisture isnt a problem really, assuming you empty / recompress the air before you use it.
board2death986 said:lmao good to know it wasn't just me and my dumb friends trying that, we messed around with our hands and a few flys and i got home and freeze dried a spider that was getting his web too close to my computerHAHAHAHAH, taught him not to fuck around with my workstation
mikeblas said:What did you read that makes you think air from a compressor (even a properly emptied one) doesn't contain condensation?
Lord of Shadows said:lol, I have an air compressor, if you let air sit in it and spray air onto you hand it will be noticeably "wetter" than if you empty/refill the thing. If that isnt enough you could get down and release the little water valve thing and/or put a water seperator on it if you have one. (I have two but never use the things when cleaning out the compy)
Boozer said:hey i forgot about that. my scuba tank is half full. do you use the smaller gun tank directly? or the scuba tank? i have a 48ci 3000, should do the trick. all the same. good idea sir!
Avalonthas said:The canned "air" shoots out like a liquid nitogen type freezing stuff when u turn ti upside down, atleast the air here in Toronto does it. Its neat to catch spiders with cuz it freezes them to the wall.....crule but interesting.....weird sensation when u try it on ur skin too however dont put it on ur skin for too long duration in a single spray because it will get frost bite and will die off, and it will either hurt or look badI recommned the 4 second rule if u can stand it for that long, it gets hecca cold
Rix2357 said:What little water that gets sprayed out usually just dries up pretty quickly even in the most humid of places.
TVersetti said:I dunno if Shoney answered it, and if he did, I didnt see it....
So where did you get that corner desk? its SEXY
With desks, mines always full of dust. I dont really mind it all that much, mostly because usually I am too lazy to clean if off, and its basically just a pain in the neck. Thanks God for dust!![]()
