keep upgrading computer
Hey
I wondered if it's (easily)possible te keep upgrading the hardware of your computer, so you would never have to buy a new one.
Only a new part every now and then..
dave..
That's what I've been doing for the last 10 years....so yes it's possible. The thing is that you usually have to upgrade the Motherboard, CPU and RAM all at once (assuming you build 1 computer per generation), but everything else can be upgraded separately.
You'll probably be spending ~$500 at a time for upgrades.
Thats what most of the people on here do. I always say there are two philosophies regarding this:
1- Build a new system every 2-3 years and don't touch it in-between
2- Upgrade a bit here and a bit there constantly, keeping your parts current-gen. This allows you to resell your older parts as they should still have some value. In the end you probably do spend a bit more than #1 but you always have the latest stuff.
Easily possible, but not so friendly to your purse :(
And as Citizen said, CPU/Mobo/Ram is almost usually a package deal.
I think GPU and storage upgrades are more common for me.
CPU/Mobo and RAM I usually invest to last a few years.
A good power supply and a good case/fans are things that usually last through generations.
Thanks,
So basically the main reason why(almost) no one does this is because it will cost you more money?
And what about the computer housing and new items for instance when they introduced hdmi, or usb
Does this just fit in the old computer casing or you need to buy that new?
And just to be curious, how difficult/ how many time does it take...to keep it up to date?
All it takes is money to keep it up to date.
Yes you can generally use your old case, and swap in a new motherboard and whatnot which will include new technologies like usb3 or hdmi. However some stuff will be on your peripheral cards, like video outputs are generally on the video card, but in some cases they are on the mobo.
There are some 'standards' that parts conform to in order to make this possible, For example there is the ATX standard which includes a backplate that is roughly 2"x5" or so that contains most of the external facing ports on the motherboard which stick out the back. Each motherboard comes with a custom 'I/O Plate' that goes into this rectangle and has the cutouts for the exact ports on the motherboard it came with.
Examples:
Here are the ports:
And here is the IOShield:
Each motherboard model has it's own backplate, and as new technologies come along new stuff can be included here. All the case has to do is have the single rectangular hole.
and all the outputs (usb internet, hdmi)
Do they all need to be on the motherboard?
Let's say you have an motherboard and USB3 comes out...could you also only change the usb port and update a driver? Or do you need to change the entire thing?
I have a staggered update schedule:
Year 1:
Update CPU/RAM/Motherboard
Year 2:
Update GPU
Basically alternate back and forth. Think I'm going to skip 2013s CPU/Mobo/RAM update though. My 2500K has been holding out nicely.
Things like PSU / HDs I purchase as need arises, but that's pretty infrequently, as I'll buy a good PSU and keep it for 5 years, etc.
I've been doing this since 1998....my next upgrade will probably only have the ssd, hard drive, keyboard and mouse from the old system.
How difficult it can be is largely dependent on a variety of factors like your skill level with building PCs, what case you have, how good you are at cable management, your choice of parts, your luck, etc.
How many times it takes is, again, dependent on a variety of factors like whether or not the parts you have is currently meeting your needs just fine, whether or not you need significantly greater performance, whether or not the next step up over your current parts are worth the costs, your exact definition of "up to date", whether or not you always want the latest and greatest, etc.
Not necessarily since you can always buy add-on cards that provides an Ethernet port, USB ports, eSATA, and video cards for HDMI. But many motherboards these days comes with all of that already.
No. You would have to buy an add-on card that has USB 3.0 ports in order to get USB 3.0 speeds. However, USB 3.0 devices will work with USB 2.0 ports but only at USB 2.0 speeds, not USB 3.0 speeds.
And by the looks of your sig you did it from 1998 till ~2002ish, or you could also say, you stopped a decade ago.
You can add new stuff by installing a card that provides new ports, but you can't change the ones on the mobo unless you change the board. Due t the fact that the CPU and mobo are pretty tightly integrated you will generally be replacing them together. RAM is also pretty well integrated as by the time a new gen of CPU comes out there will be new RAM standards and so you'll need to get that too.
Done it for years. For one of my PC's I've had the same ATX case since around 2002. Nothing else is original, though. Oldest thing in there is probably an Atheros PCI WiFi-G card.
Allright so I made a list with all the computer components ( if i miss anything please let me know)
Could you tell me how long it takes before you upgrade that particular part?
It's the research for my graduation project and I want the know the average lifte time of each component before it's upgraded.
Thanks a lot! :D
Motherboard
videocard
RAM
CPU
Hard Drive
Network card
Sound card
Disc/dvd/floppy drive
Cooling (fans)
Power supply
The Casing
Extra:
Screen
Mouse
Keyboard
Speakers
Dave
Do you mean in general or for that one person or for that particular series of upgrades?
In any case, there really isn't a general set time IMO when one should upgrade a certain part. It's all dependent on a variety of factors like:
- Suitability of old part to be used with new parts
- Performance and capability of the parts
- Pricing and budget
- The User's performance and capability needs
- Luck (as in whether or not you were unlucky in choosing a certain part that was defective from the get-go or became defective over time)
As a result of those five main factors (probably a few more that I forget), the lifetime of a PC or PC parts is gonna vary significantly from person to person. There's a few people here on the forums who upgrades their PCs virtually every year to either get the most performance possible or simply as something to do with their PC hardware hobby. Then there are those who only upgrade when a part has died or they didn't do enough research ahead of time to make sure that part was a good choice. Or the ones that upgrade due to their need for higher performance for one certain app, game, or range of usage scenarios. As such, a relatively accurate average of the lifetime of a part may be hard to obtain unless you made sure that you only got results from a group of people having the same usage with their PCs, have similar performance requirements, have similar budgets, and even similar ability to choose parts.
So for example: If I bought a Corsair TX750 750W PSU for my PC 5 years ago, it would actually still be good enough for most upgrades I do now assuming that it survived that long. However if I bought a 400W crappy PSU five years ago, I would have had to replace that 400W PSU 4.5 to 5 years ago before it killed the rest of my PC. Alternatively, if I plan on going for a triple or quad SLI/CFX setup for my latest upgrades and/or are totally tired of having all those PSU cables in the way and thereforee need a modular PSU, I'd have to ditch that Corsair PSU. Or if I had a case of bad luck where that 750W PSU became defective over time or there was a really bad power surge, I would have to replace the PSU when that occured.
So yeah, it's pretty easy come up with several different scenarios where you would have to replace a certain part after varying degrees of time and usage needs which really would throw off your averages.
I've gone both ways over the years. CPU's these days can last a long time if you're willing to overclock them. You can push a first gen i7 pretty far with a $40 cooler, so that can extend the life of your CPU, motherboard, and RAM for years if you want.
If you're looking to build for the long haul - don't skimp on your PSU. Go modular, and go slightly bigger than you need.
Video cards are the most important component for gaming and it isn't even close. What you go with there matters most, but potentially also costs most, too. On the other hand, it's also easiest to upgrade, too. Swapping video cards can be done in literally about 3-4 minutes, and a new card can add a lot to even an aging system.
Lately I've been in the mode of slow upgrading, but using Craigslist to help. Whenever I want something new, I sell whatever I'm currently using on Craiglist and use that money to finance part of my upgrade. You'd be shocked how well it works, and as long as you aren't charging too much - everyone wins.
