K8N Neo4 Plat/SLI with Geil memory?
boy_wonder
I just ordered an MSI K8N Neo4 Platinum SLI mobo and I was trying to decide which memory to get. I looked at the Geil memory shown here and I was about to get it. Then, I checked the MSI website and I looked at the supported RAM, and it wasn't there. I just wanted to know if I can use this RAM with this mobo or if anyone else has done so successfully. I mean, I don't see a reason why, but I just want to make sure.
PS- A n00b question- I can use higher than PC3200 RAM with this mobo correct?
You can use higher than PC3200 and you can probably use the Geil memory. You might have to run a little higher Vdimm to get it to work stable though.
Yes, you can use higher than pc3200. I think you willl be ok with normal settings with Geil, but I heard that Geil memory and nforce chipset setups don't play that nicely when you try to o/c. Don't have personal exp., but have read this and heard abuot this so take it for what it's worth.
Doesn't work fine for me...I have the pc4000 platinum ram and I can't go past stock htt w/o random restarting when it tries to load windows. I'm buying a new board and memory as well.
