Just ordered Razer Diamondback...
dderidex said:
Correct, one of the many reasons wireless is technically inferior to corded mice. (Whether you'd notice the difference or not depends on the person, of course, but wireless IS inferior)
yes but that is only because there is only so much that can be doen with out wires...
Exactly.
I've just grown weary of post after uninformed post in other areas of this forum and other boards proclaiming how superior wireless is to wired. The "laser" Logitech MX1000 not helping matters at all.
Fact is, specific products aside, wireless is inferior to wired. The only argument that could possibly be made in favor of it is that it has 'convenience' by not having a cord - but that hardly makes sense to me, as you immediately run into the very pronounced INCONVENIENCE of having all the excess weight of batteries in it, and having to recharge the damn things all the time.
All for an effect you can get just as easily with a 'wired' mouse using a mouse bungee.
I was simply trying to prevent this thread from veering off into that direction.
Anyway, looking forward to your thoughts on the Diamondback.
My "old", well not really old since it's an OEM replacement, 1.1a Intellimouse Explorer can do 1000mhz with that patch. I have it set to 500mhz though since I want to avoid the instability that 1000mhz gives. I noticed a difference from the default right away.
dderidex said:
Actually, both files DON'T need to be changed using this method, and you don't need to boot into safe mode.
How Windows File Protection works is that it checks the timestamp on the file, and the size of it. If it's different from what is in the dllcache folder, it "restores" it. This util is taking advantage of the 'save' vs 'save as...' functionality of windows. "Save as..." will create a file with an updated timestamp on it, so doing a 'save as...' and copying over the old file (or extracting a file from an archive and copying over the old file) will change the timestamp, and cause File Protection to trigger, over-writing it (unless you do the safe mode thing and replace both of them).
What this patch does is just 'save' after making the hex-level modifications. The way it does it, it does not update the timestamp, nor change the file size. So, you can do this with Windows while it is running, just reboot, and your changes will have taken affect.
If this patch copies the usbport.sys to the dllcache folder (I think), it would be added to the 'cache' and it will be defaulted to load everytime. If it doesn't, then it will revert to 125 hz everytime you reboot after THAT reboot. I've tested it and concluded that (it was done manually with manual hex editing). If it worked for you everytime you reboot without the need to copy it to that folder then somehow it worked anyways, heh. :)
-J.
-J.
Logitech allows 200hz with the Mouseware. Any MX510 owners have experience with any patches?
Once I format my PC (which is today or tomorrow), I'll update you with the patch testing.
-J.
any questions about the razer diamondback, feel free to post on this thread and ill answer them as best as i can :D
I noticed you listed that you got the 'Chameleon Green' version - can you post some pics?
I'm dying to see how this looks 'IRL' - as I get the feeling the pics on the 'net just aren't doing it any justice.
FWIW, fearing that it looks crappier in person than the beauty shots, I went with the 'Salamander Red' one, so we'll see how that goes.
Oh - I'm assuming you ordered it directly from razerzone.com, right? (*I* couldn't find anyplace else to order it) How long did that take? I just put my order in today - early afternoon. Can I realistically hope to see this next week?
yupp, it could easily get there the next week, as soon as i take some pics i will post them up here. It does look ALOT better in person than in the photos, its one helluva mouse
worth every penny imo
