Just looking for some advice for my next setup.
Cottonwood00
Here's the Deal, I'm looking to upgrade my setup and its been awhile so im looking for some advice for my next setup. Ill begin first off buy saying that I'm trying to turn my existing computer into a HTPC and build a new computer. My computer i have now is kinda old but I dont game as much as i use to so my next system doesnt have to be top of the line. Im looking to keep the price anywhere from 600-800 total.
This is my Current system:
AMD x64 3200+ ~2.0ghz
1GB DDR ram
Radeon 9800Pro
1 80Gb HDD
1 15gb HDD
CD/DVD burner
Gigibit Ethernet card
500wtt PSU
**Im not looking for any screen or keyboards cause im keeping my LCD screens. Oh but i need a new case for both systems cause the case i have now is incredible old and broken.
So I guess im asking how would you set up a new system with HTPC if you only had about $800?
I few things I think i want in the setup:
I want to be able to play HD with my HTPC w/ about 500-750gb HDD space. And in my Main system enough power to handle alot of multitasking whatnot.
I would like any advice, and how you would remedy this situation. I would spend more but im tryin to get a new LCD tv.
thanks
Is the $800 for both the upgrade on your old system as well as building a new system?
And out of curiosity, what's the specific make and model of the 500 watt power supply?
In order to watch HD movies with that old system, you'll need a newer vidcard that can help with the video decoding for vc1/h.264 (the CPU is a bit weak). Is your board AGP or PCI_E? Go for something like the HD 2600 pro/xt, or 8500gt/8600gt/gts.
Your setup is almost identical to mine, except for the graphics card (I have a Geforce 6800).
After looking over everything, I've found that the money that you need to upgrade just isn't worth it.
For example, for an HTPC, you probably need a better graphics card. Unless your motherboard is PCI-E, you won't find much along the lines of AGP anymore. Upgrading the CPU is probably cost prohibitive based upon what your mobo can support. No point in only upgrading to a 3400+ for instance.
Also, DDR vs. DDR2 RAM prices are crazy. It seems like 1 gig of RAM is nothing now. PC3200 RAM (what I have in my machine) just isn't worth buying anymore.
Heh, I guess it was too early in the morning for me to remember that the 9800Pro only came in AGP. Anyhow, your best choice for vidcard, with HTPC duties in mind, would be the Radeon HD 2600Pro.
Sorry i've been on spring break and have not checked this post in awhile, so to clear things up the 800 would be to upgrade and to build a new setup. Also my mobo has PCI-E, and AGP. What ive been thinking now is maybe try and pick up an older 939 x2 and a newer PCI vid card nothing to expensive just enough to play HD then put the rest into a new build most likely a AM2x2 64, nvidia 8600, 2 gigs of ram, and lots of HDD space.
Sorry i've been on spring break and have not checked this post in awhile, so to clear things up the 800 would be to upgrade and to build a new setup. .
Still a bit confused. That $800 is just for a new PC correct? And upgrading your current PC to handle HD content is part of a separate budget?
And some questions that need to be answered:
- What parts do you need for that $800 budget?
- What are you planning to do with this PC?
- What features do you need in a motherboard?
- Will you be overclocking?
Hmm...if he upgrades the CPU/Video/HDD in his current setup for HTPC, he's spending about $200-$250 range. The rest of the $800 bucks your left with $550 - $600 on your new build.
The 800 would be both for a new rig and to upgrade my existing one, but for the new rig i dont need screens or anything just the rig. The pc i have now i want to use as a HTPC/Server for testing and compiling. In the new mother board id like digital sound and analog w/ PCI-E, and a current socket so i can upgrade in the future. Other then that i probably wont be over clocking to much. But i def want a dual core or more cause ill be doing music editing stuff.
- Will you be gaming at all? If gaming, what games?
- Do you already have a spare OS license?
- As for HD, do you mean 720P or 1080P?
Well no i wouldn't be gaming to much on the HTPC, but ill probbaly play a few on the new rig and if i do im thinking like COD4 or Team fortress. And yes another OS lisence, and 1080p if possible
For the HTPC, pick up the 8500GT since your mobo has a PCI-E x16 slot. That should handle 1080P relatively well. That's $55 to $65 there.
As for your new build, what EXACT parts do you need? Hard drive? Case? PSU? OS? etc. Please be as SPECIFIC as possible.
Well im not sure to tell you the truth im looking for optimal power, So for the
New Rig i want a dual core AM2 for upgrading, 2 gigs of ram, HDD space im trying to get about 250 in my new rig and 500 in my htpc, and a vid card with DX10 but no need for top of the line. Other then that i have a OS (free from school) and a screen, the PSU what ever is cheap but reliable and case dont really matter.
For your HTPC:
MSI NX8500GT-TD256EH GeForce 8500GT 256MB - $60
Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive - $98
Total: $158 PLus tax and shipping.
That leaves us with $642 for your new PC. Which is, surprisingly, more than enough:
Intel Pentium Dual Core E2160 CPU - $70
Arctic Cooling Freezer 7 Pro HSF - $22
Gigabyte GA-P35-DS3L Intel P35 Motherboard - $90
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB DDR2 800 RAM - $45
Foxconn FV-N96TM3D2-ON GeForce 9600GT 512MB PCI-E Video Card - $155
Corsair 550VX 550W PSU - $89
Western Digital WD3200AAKS 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $74
Samsung SH-203B 20X DVD±R SATA DVD Burner - $27
Cooler Master RC-690-KKN1-GP ATX Case - $62
Total: $634 plus tax and shipping.
I recommend ordering the listed 9600GT ASAP. Dunno how long it'll stay at $155. That's a great price for an awesome video card. OC the E2160 to 3.0Ghz and it'll beat any AMD CPU clock for clock. However if you don't plan on overclocking, go with the build above but replace the HSF, CPU and mobo with:
AMD Athlon64 X2 5000+ CPU - $100
MSI K9A2 CF-F AMD 790X Motherboard - $90
Total: $190 Plus tax and shipping.
TBH, I'm not too familar with Socket AM2 Opterons. I do remember their socket 939 being good overclockers but not too sure about their AM2 brothers. Also, the Opteron isn't officially supported on the mobo you chose. Though there's a really good chance that it will work anyway. Also, I don't know how socket AM2 Opterons compare to their desktop counterparts.
However, you might want to check out the 5000+ Black Edition instead:
AMD Athlon64 X2 5000+ Black Edition CPU - $100 (No HSF)
It has an unlocked multiplier, which should help OCing but doesn't come with a HSF.
From a performance standpoint, your plan is kind of a bad idea since an $70 OC'd E2160 will beat any AMD CPU clock for clock. But if your looking for a good CPU at stock speeds, that Opteron or X2 5000+ might do the trick.
