passkey done, GPU0 setup on my GTX460. one of each done already.
keeps the computer room nice and warm![]()
The only reason I don't run 4.0 is that 3.5 is enough that the 212+ fan still runs really quiet. plus it maxes out my BFBC2 nicely with a mild overclock on the 460. I'm happy
I don't have an EOC number, is it imperative that I get one?
I also just joined, trying to figure out how to get my 5770's set up correctly atm
and am i confused because ive been up for hours, or can i just not get my F@H client to use more than 25% of my CPU, ive tried the slider and everything, it refuses to budge??
the -smp flag goes into the additional parameters box?
yes or if you are using the real smp client and not the gpu tracker you can create a shortcut and put the flag in there.
the flags i run are -smp -forceasm -verbosity 9
the -forceasm flag isn't required but i run it anyways since i'm stuck in my old ways.
... I don't think I even need a second one...now to think about 4.0GHz..
If you are overclocking, a push/pull on your 212+ is no louder, provides better cooling and adds the safety net of redundancy. I consider it $20 worth of insurance.
Plus it makes your heatsink look diesel as all hell.![]()
