AuroraProject
- Dec 13, 2004
and I got a 50,000 frame WU right off the bat! I've completed 11500 frames so far at 6.2 seconds per frame. I just wanted to add my spare cycles to a good cause and be a part of the #1 team.
Don't forget to install YURT!
Thanks folks, I'll look into Yurt.
I do have a question though, what happens if I'm in the middle of a WU and I need to reboot? Can I pause the work, reboot and unpause, or does it lose all work up to the point of reboot? And is there a way to make it use more memory? I have 2 gigs and it's only using roughly 512mb, when the computer is idle I'd like it to use more.
If you want to be a cool [h]ard folding member you have to take a [H] boxen sticker and stick it on one of the kangaroos at your local zoo and take a picture so we can send it to the Aussies!
And make sure both are console clients as well...make a new folder and rerun the setup and make sure you use machine id 2 for second core
I just joined last night. I'm not gaming on my PC as much as I used to so I thought I would put it to use.
All the guides and FAQ's were very easy to follow and very informative, thanks to all of the people who put in the time and effort to set them up.
I'm going to switch to the console version tonight to take advantage of my Opty.
