- Oct 29, 2000
So,
I was under the impression that vmwares E1000 emulated gigabit adapter is just that, gigabit, and that VMXNET3 is a virtual 10gbe adapter.
But then I just ran some iperf testing I can't wrap my head around:
Configuration is two guests on the same host:
Guest1 ---VMXNET3---> vSwitch ---VMXNET3---> Guest2
Is VMXNET3 not strictly tied to any particular speed? If that is the case, why does it stop at 13.3 or 18.4Gbit and not go higher? CPU limitation?
This is on a dual 6 core LGA1366 Xeon (12 cores +HT @2.25, turbo to 2.8Ghz)
Appreciate your thoughts.
--Matt
Code:
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[ 4] local xxx.xxx.xxx.xxx port 5001 connected with xxx.xxx.xxx.xxx port 42984
[ ID] Interval Transfer Bandwidth
[ 4] 0.0-10.0 sec 15.4 GBytes 13.3 Gbits/sec
[ 5] local xxx.xxx.xxx.xxx port 5001 connected with xxx.xxx.xxx.xxx port 27820
[ 5] 0.0-10.0 sec 21.4 GBytes 18.4 Gbits/sec
--Matt
