this is pretty frustrating. i guess i did put it in correctly the first time but neglected to do anything with the lever, but now that i use the lever it doesnt seem to do anything at all..
and no pins are bent, first thing i checked
edit- just re-seated the cpu properly and still nothing.
if it boots up but no post, clear the cmos with the jumper... then try it, if that still doesnt work take the battery out for 10mins or so and then try.
if that doesnt work...... go to bare min specs
CPU 1 fan, 1 stick of RAM , no HDD, no extra GPU or expansion cards of any kind.
it should not be that difficult to get the CPU in and if you put the HSF on with the CPU not seated correctly.... you are screwed b/c you bent the hell out of a bunch of pins.
no, i didnt plug the molex in.. ive never ever seen that on any motherboard . now that i look at the cpu it has a bent pin.. imma try and adjust it back, wish me luck.
