Just Built a New Rig, Having Major Problems
Jpsheff
Hi, this is my first post here at Hard Forum. I recently just completed my first new build (specs in sig) and I am having a wide range of issues. When I run Firefox, CSS, CnC 3, or pretty much any application I get a .exe error after a while. I also get serious artifacting in some games such as CnC 3, and Lost Planet. My computer also locks up in games, forcing me to restart it. When I do restart it, sometimes my computer will load windows and then restart again, and again, and again, et cetera. I'm not however getting and BSODs.
Thus Far I changed out the RAM and tried different RAM slots. I also tried a different video card, another 7800 GTX, and that didn't seem to change anything either. Additionally, I switched out the hard drive once, as I was having a formatting error with the first one I purchased.
At this point I think it is either my motherboard, or my PSU, but again this is only my first build.
Does anyone have some suggestions?
wow...congrats on your first build...they don't all go like this, and I am sorry to hear that you're having all of these issues. It sound either like a driver issue, or a problem with a hardware component, something that would affect overall system operation...RAM, mobo, CPU, PSU, HDD. I lean more towards the software on this one, given that all of your parts are brand new. Before you loaded windows, did you have a chance to go to all of you parts manufacturers websites, and download the latest and greatest software driver packages? Have you looked to see if there was an updated BIOS revision for your motherboard? Manufacturer's links to follow this post. Please confirm or deny that you have or have not downloaded and installed the latest drivers/BIOS/Firmware revisions.
ASUS P5N32 SLI Premium support page:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI Deluxe
-make sure you flash to newest BIOS 0405 before proceeding with Windows install. also, make sure that if you are utilizing RAID (although from your rig specs, it doesn't appear that you are) that you download the drivers for the RAID controller, and that you are pressing F6 during the XP installation to load those drivers. You will want this one:
WinXP
Version V1.2.3.1 2005/10/05 update
Description Silicon Image Raid Driver V1.2.3.1 and Utility for Windows XP/2K/2003(WHQL).
File Size 15.22 (MBytes)
Download from Global USA Europe China Japan
-Also, once you get into Windows, you will want to make sure that you are installing your motherboard chipset drivers FIRST, before anything else. When you are asked if you want to install specific packages during the installation, MAKE SURE YOU UNCHECK THE "NVidia SW IDE Driver". That package, with IDE optical drives, will completely lock your system, in most cases. After the main chipset drivers are installed, continue on with the remaining onboard items (sound, ethernet, wireless, RAID, etc)
Nvidia 7800GTX support download page:
http://www.nvidia.com/object/winxp_2k_94.24.html
I don't see anything else in your rig specs that would require drivers. Make sure that you have BIOS set properly. If your CPU is set to autovoltage, and RAM is as well, you may try finding the values that they should be set to (from manufacturer specs list), and setting them manually in BIOS. Your errors could also be caused by an undervolted CPU (which could be autodetected at a lower than rated setting if the BIOS is out of date).
I have the latest drivers for my motherboard and video card, but I have not checked for any BIOS revisions. I'll do that and get back to you.
Thanks for the quick reply
the drivers were installed in the correct order then, I can assume? RAID (if required, during XP installation via F6 key), then once in Windows, the chipset drivers, then sound, ethernet, wifi, then video? Not that it matter really in what order you choose to do them, as long as the chipset driver is first.
Yes, I installed all other drivers after I installed the chipset driver. I also just flashed my BIOS with the latest revision and had no luck : / .
I would guess, since this is the first built, that there is no spare board with which to test?
Could be RAM problems. Google, download, burn and run Memtest+ for at least 3 hours to see if you have any RAM problems.
Sometimes new parts are defective.
Unfotunatly I don't have a spare motherboard to test. I'll run Memtest to double check but I'm pretty sure its not the ram.
Oh and for testing hard drives, google, download, burn and run Drive Fitness Test to see if theres anything wrong with the hard drive.
I'd would definitely check the ram, bad memory always causes the most random problems. Since you mentioned bad artifacting, have you checked the temps of your case, cpu, and video card just to be sure your new setup is ventilated well enough?
Atifacting is almost always a PSU or Vid card, but with all the other issues who knows. If this is a 680i Asus the 1103 or 1104 bios can do wonders for memory capatiblity ( i know, i own one), as they are know to have some pretty wide compatibility problems out of the box.
Just an update / additional error that may lend some more insight into the issue. When I try to open the Nvidia Control Pannel, my computer locks up and restarts.
Artifacting imo is almost always video related, i say try reseatinig your video card, then double check your power connection to your card
Are you over clocking anything at all?
With the artifacting, I am thinking his card might be bad if reseating it doesn't work. My first build had a bad card that I had to return to NewEgg, and being impatient I went out to Best Buy and bought the best ATI they had in stock at that store, and ate the NewEgg restocking fee.
