This is something i've always wanted to do and just finally got around to it..
My goal with this mod (a very easy mod) was to convert my desktop joystick into a floor joystick, essentially to be similar to what a real pilot would use..
the joystick i have is the thrustmaster force feedback afterburner (if this didn't work i was going to buy a new stick anyways)..
before
and after
What was involved:
1. A PVC Tubing about 36" long that i cut..
2. 24guage wiring to extend the button electronics
3. 5/8" wood dowel
4. 2 1" hose clamps
I was worried before starting this it would be a moster project, it ended up being pretty easy.. the PVC i got (was actually a 36" Riser in the spinkler section - $2.19) ended up being just the right size to go over the end stick when i removed teh handle.. .
i used a piece of dowel to extend the handle out of the PVC Riser
this pictures are blurry but i am too lazy to take some new ones
The Handle
TheBase
the most time consuming part was the soldering as it was 6 small wires i had to splice and my fat fingers didn't want to cooperate..
Now someone might ask why , well beyond the fact just for heck of it.. i'm finding it to be more and immersive when playing flight sim games (i haven't tried in BF2 yet as i don't use a joystick for bf2)...
The increased precision is nice as the range of motion has gone from an 8" diameter circle (from the top of the handle) to a 24" diameter circle (approximately)
the one thing to be careful is you have much more force at the base of the stick when you hit the limit, could easily start breaking some plastic pieces ...
the next project is to build a wood base for the stick that will house the Throttle assembly so i can sit back in my chair and fly the trecherous skies.. This will also allow me to use it while sitting my big fat ass on the couch...
PS.. yes i have too much time on my hands..
before
and after
What was involved:
3. 5/8" wood dowel
4. 2 1" hose clamps
The Handle
TheBase
