Ivy Gaming Build
Rhyno37
Hey there guys, looking for some assistance in my new build. It's been 5 years since I last built so I'm out of the game and know very little on what's good and not now. All help is appreciated!
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Gaming, Browsing, some school work. I'd say 60 percent browsing, 40 percent gaming
I'd like to keep it around $1300 tops. Might be able to exceed that by a couple hundred if its worth it
USA: Peoria Illinois
CPU, GPU, HDD, PSU, Case, Memory, Heatsink, Mobo, a fresh build. Everything but the OS
None
6) Will you be overclocking?
Not planning on it, very small chance
1920x1080 23"
Within this week or next
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0 and SATA 6.0GB/S maybe? Like I said I've been out of the game for a while. Unlikely to run multiple GPU's
Yes, 64bit
Only part I'm pretty sure on is the case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
Other than that, everything's up in the air.
$200 - Intel Core i5-3450
$135 - MSI Z77A-G45 Intel Z77 ATX Motherboard
$38 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$400 - Gigabyte GV-R795WF3-3GD Radeon HD 7950 3GB PCI-E Video Card
$125 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$120 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$23 - Lite-On iHAS424-98 DVD Burner
$90 - Corsair 650TX V2 650W PSU
$162 - Corsair Obsidian Series 650D ATX Case
$25 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
Total: $1318 shipped.
A little over budget but totally worth it. Some notes:
- The SSD is for your OS, small spps, and some games. It'll definitely speed up load times.
- The parts with Amazon.com links should be bought from Amazon as that'll save you $40 to $50 or so.
