Do you think Ivy Bridge Chips will have a higher overclock potential than Sandy Bridge? Possible to get to 6+ Ghz?
Besides being able to run at that high a multi it also depends on what the BIOS limits it to. SNB has already been run with 59x multi and that is IMO likely a BIOS limit with SNB having a real limit of 63x.Also, is it true that Ivy has a x63 max multiplier setting compared to Sandy's x57?
I do not think 6GHz will be possible (under normal cooling) from the Intel's graphs on what 3D transistors bring. It seems you get a combination of performance and lower power however once you raise the voltage significantly over 1.0V both 32nm Planar and 22nm Tri-Gate appear to converge. Intel did not provide that part of the graph so we do not know for sure exactly where or what advantage 22nm Tri-Gate has at 1.X V.
Edit: Here is what I am talking about:
When it comes to the hardware side, we were shown that the processor excels in performance. We saw the samples of Core i7-3770K going from 3.5 GHz to a massive 7.06 GHz clock. By raising voltage to 1.889 Volts, using 63x multiplier and 112.11 MHz and using dry ice - the 22nm beast passed 7000 MHz.
Not sure if that is any more useful than the 8.X GHz AMD demo.. I mean 1.89 volts for a 1.0V to 1.2V chip. Not like you will be running at that speed 24/7.
