Since I began using computers I've always leant towards ABIT motherboards but after tonight I've had enough.
2 years ago I purchased an ABIT IS7 motherboard (865) and had issues with the fan on the northbridge stopping. The fan burnt out, and my northbridge fried.
I then went out and replaced the board with an ABIT IC7-G (the one with the OTES cooling).
6 months later again, the fan dies, but the motherboard lived. I took the pc to a repair place (I lose patience with fixing my own gear sometimes) and had them replace the northbridge fan with a passive one.
Tonight I came home to my PC having strange visual artifacts on the desktop. I restart and the problem comes and goes until entering a game I notice it immediately garbles the image. I right away recognise this as a heat issue and open the case.
Sure enough, the clips that northbridge fans use to stay fastened to the motherboard had popped out - this is the second time on two motherboards I've had this.
I've tried writing to ABIT in the past about the poor fan and clip system they've used that has resulted in one of their motherboards needing replacing.
Tonight I was lucky, as a metal heatsink and steel clip resting ON a graphics card could have done much, much worse - the lesson I get from this is that I should not trust a motherboard manufacturer who twice burns me with the same weakness in their systems on two separate boards.
As much as like ABIT motherboards I just would not recommend them as an unattended 24/7 machine due to my experience with both poor quality northbridge fans and even poorer clip mechanisms for the northbridge heatsinks.
Any other feedback on similar experiences would be appreciated.
